Uses a smaller heatsink and a user-screwable stand.
Why won't my ps5 turn on
I didn't use it for 2 days and now when I try to turn it on, it won't power on. I tried different outlets, powercords, and cleaned the inside.
Это хороший вопрос?
Счет 0
2 Комментариев:
Does it have any signs of life when you try to power on? Lights or the fan spinning?
из
@flannelist No, nothing turns on
из
Добавить комментарий
1 ответ
Hi Antonio!
In this case, I would open it up and check the Power supply. It should measure 12volts also in standy by mode.
If this is not the case, then I would replace it and see if that works!
Guide: PlayStation 5 Power Supply Replacement - iFixit Repair Guide
Please let me know if you have any questions!
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Antonio Cabrera буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 39
