MacBook Air does not turn on
MacBook Air M1 does not turn on, however when plugged in im getting haptic feedback from the trackpad. i have tried multuple power cables, pressed and hold the power button a billion times, tried all the different keyboard combinations, plugged into an external monitor, popped it open and disconnected the battery and trackpad and reconnected it, and still nothing.
Это хороший вопрос?
Счет 0
13 Комментариев:
please someone answer i am willing to provide additional into upon request
из
Are you getting additional signs of life? Keyboard backlight? Does the caps lock LED come on when you press that key?
Trackpad haptics come on very early in the boot up sequence the other things come later. If the caps lock LED comes on, it's likely that you aren't getting a display rather than no power.
из
@flannelist no i am not getting anything except the haptic on the trackpad
из
@picket - Can you give us some history was the system serviced before? Do you have access to a second Mac that you can connect via Thunderbolt to see if in DFU Mode the system is able to see the system.
из
@danj yes i tried that and alsoi took it to the apple store and they said it was gonna take 600 to fix sooo. its bricked. thanks dor your suggestion tho
из
Показать ещё 8 комментариев
Добавить комментарий
