Yikes! Why does it look like this
Why are the colors just grey and dark normal colors just look at how bad this is
Это хороший вопрос?
Это хороший вопрос?
Hi!
Please check the Wii display settings and see if you can change some settings there and see if that solves it.
If possible, please share a screenshot with us regarding the display settings.
Can you also share the details about which Wii > HDMI adapter you are using?
If the settings doesn't change anything, then it's might be a faulty HDMI adapter, or a compatibility issue (TV and HDMI adapter).
So you can try a new HDMI adapter (or from a different brand) or try it on another TV.
Please let us know how it goes!
Был ли этот ответ полезен?
I changed the settings and I rebooted the Wii and now it has the sound of death which is when it freezes after the Wii health and safety screen and it makes a terrible sound. I think my Wii is just dead
I would stop using the HDMI adapter and just connect the original AV cable. See if everything is OK now. If this is the case, get yourself another HDMI adapter from a different brand and test again.
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 4
За всё время: 67
3 Комментариев
Hey there Cat, have you tried checking if your TV's input to Composite? It might be that your display was set to AV or Component accedently. Otherwise, try a new AV cable.
из Jacob Mehnert
I am using a Wii to hdmi adapter and I tryied a few other hdmi cables
из The cat15
And thare is still a issue
из The cat15
