MacBook does not enter safe sleep after battery replacement.
Hi all
I recently got my MacBook battery replaced and an aftermarket battery was used. It works and powers on the computer but for some reason, when the battery reaches 0%, it just stays there and when the computer shuts off, it doesn't enter safe sleep. Instead, the computer just shuts off. And when I push the power button, I don't even get the low battery icon or any fan spin it's just dead. After plugging in my computer, instead of resuming where I left off like with my old battery, all the apps have to reopen from the start.
I would have expected it to hibernate or enter safe sleep upon low battery percentages like with the factory battery.
Is this something that should work or is this just a limitation of aftermarket batteries? Maybe the aftermarket battery I have isn't the best as it's shown 89.5 degrees and never changed. On a different MacBook I had, I got an egoway battery for my 2015 MacBook Air and safe sleep was supported. Or is this just a defect with my battery?
I already did the whole SMC/PRAM reset stuff and I got the same thing. Or should I calibrate it one more time and see what happens?
EDIT: I have around 27 cycles on my battery now and when I went to use my computer, it died around 3 percent which was expected but what was more surprising was that when I went to wake it, it had actually hibernated this time and woke from safe sleep instead of just shutting down and losing all my stuff. Not sure if a MacOS update fixed it or I had to keep using my computer to get it all calibrated but it looks like my computer fixed itself.
Это хороший вопрос?
8 Комментариев
There are 3 or 4 files under library/Preferences/ com.apple.Power*, delete them, empty the trash, restart, did that make any difference?
из livfe
Your batteries temp is a bit high, are you running a heavy process game or video rendering?
из DanJ
@danj No it's right after power on. I don't think the battery sensor is working as it's been showing 89 degrees regardless of the condition so might be an aftermarket battery quirk.
из jimmysofat6864
@livfe I did a clean install then attempted to calibrate the battery. I viewed all those files and they are essentially blank.
из jimmysofat6864
@jimmysofat6864 - That's not good 😡 best to get it replaced under warranty I hope!
из DanJ
Показать ещё 3 комментариев
