This makes no sense!
Hi all, really hoping I can get some help here!
So, in a nutshell, My MacBook won't turn on without being connected to power, and it only connects to power if you unplug the charger from the wall, disconnect the MagSafe charger, then plug both in. Once it boots up it's always showing the date as Thursday 1st April at 8pm, and it says the battery is always at 85% charged. But when I disconnect the charger, the laptop dies, and I have to go through the process again. System info says my battery condition is normal and it's only done 71 cycles so I have no idea. any help would be great!
Это хороший вопрос?
Let's get a bit of deeper info. Install this gem of an App CoconutBattery take a snapshot of the Apps main window and past it here so we can see it. If you can click on the battery info button as well. With that we should be able to figure what's happening.
из DanJ Поделиться
Hey Dan, everything looks to be fine, shows battery charge at 84.1% and battery health at 95%. Full charge capacity 4,336 mAh, Design capacity 4,563mAh, 71 charge cycles. does say charging with is 0mW if that stands out?
из janesboy Поделиться
@c53dgx8yju3rgxe - Yes! The zero charge is one element. But it would be easier just seeing the full image with all of the data.
из DanJ Поделиться
