4 inch display / Available in a variety of colors / Released in 3 different models / 16, 32, or 64 GB capacity
How to migrate the "iPod loop" to a new casing
I recently bought a new casing for my iPod touch 5 and it doesn't come with that little "iPod loop". I can't figure out how to separate it from the old casing, and fixit doesn't seem to have a guide for this. Can anyone tell me how to take it off?
Edit: This thing right here. I've tried everything I can, but I just can't figure out how to remove it.
Это хороший вопрос?
Счет 0
2 Комментариев:
Can you post a picture of this loop part you are struggling with. Or point to it from within one of the images in this guide iPod Touch 5th Generation 16 GB Teardown
из
Just edited my question. Y iPod is reassembled right now, so I used a picture from the teardown. The casing I bought was a secondhand one without the "iPod loop", so it must be removable somehow.
из
Добавить комментарий
1 ответ
OK, now I get what you are struggling with! This is from the iPod Touch 5th Generation 16 GB 2014 Teardown Step 2
It's not removable as then you will have a hole in the case.
Did you buy the wrong case? As the iPod Touch has a few different cases depending on the generation. Here's a great resource to help ID the different generations Index of all iPod spec's
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Leooooo1061 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 13
За всё время: 46
