LG's flagship smartphone, with a unique slide-out battery and detachable I/O module supporting multiple hardware expansion options. Released in April 2016.
What does a line through my battery mean when I'm trying to charge my
What does a line through my battery mean when I'm trying to charge my phone
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
The status bar
displays
saving mode is on.
If that isn't the right "line though my battery" then it indicates an issue with the charging such things as a bad charging cable, charger faulty, bad power outlet, worn battery, dirt etc, in the charging port, or even software glitches.
To fix it:
Try a different charging cable.
Try a different power adapter or USB port (NOT all are powered, and some that are don't supply enough for many phones.)
Look into the charging port, blow it out and or clean it with a soft brush,
You can also see if the cable and charger work on a different device to rule out problems with them.
Software issues might be fixed (usually are) with a soft reset (Reboot it, turn it off then on not just the power button to standby mode)
Good luck.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
harley буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 28
За всё время: 123
