Инструкции по ремонту и разборке 14-дюймового MacBook Pro, выпущенного в октябре 2021 года, с процессорами M1 Pro и M1 Max от Apple. Модель A2442.
Connector Came off from the Board while removing Microphone flex cable
Hi, I accidentally broke off this connector. Can you please help me and suggest how to repair this? I understand that i need to solder this back. I am not sure where to find this FPC connector? What could be the right size of soldering tip for this job. I do have a ATTEN STE 80 soldering station.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Your lucky! The solder pads are intact so you only need to replace the damaged connector.
Do you have a soldering iron? Have you soldered before? If not a good independent Mac repair shop should be able to put it back on.
I'll need to dig though the schematics to locate the part info so you can get it from an electronics parts house, this is a relatively easy part to source.
Был ли этот ответ полезен?
Счет 0
2 Комментариев:
Hi, many thanks for your reply. Yes I know soldering. Are you able to help me with the part number please ?
из Поделиться
Just unaccepted the answer for now so that this query is not closed by the forum. Thank you. I am acknowledging your help and support.
из Поделиться
Добавьте свой ответ
Gurpawan Mand буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 10
За все время: 176
