Этот выпущенный в марте 2021 года робот-пылесос оснащен лидаром, виброшваброй с гравитационной подачей воды и функцией автоматического подъема швабры при обнаружении ковра с помощью ультразвукового датчика.
Two plastic parts are leftovers but where from?
I teared my vacuum cleaner (Roborock S7 later model) down (have to change the vibrating module) and in some point I turned it (vacuum cleaner) upside down these parts dropped out on the table. The size of the fallen out rectangular black plastic part is about 13x4x5 mm including some kind of similar notches on it's each end. There are two pieces not exactly the same looking parts but the sizes are the same. I might remember they falled out after removing the main brush module and then when I turned vacuum cleaner upside down there parts falled out. The model is the later one and European (Roborock S7) . Anyone who might know these parts locations in vacuum cleaner would you please tell me?
Это хороший вопрос?
Счет 1
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Any photos available maybe?
Update (11/19/25)
The most left part belongs to the mop module. See pictures attached.
Был ли этот ответ полезен?
Счет 1
4 Комментариев:
Sure. Got to do it after work.
из
Sorry, most right part belongs to the mop module.
The other part I could find.
из
Thank you 👍👍👍. Now I know a little better where to look. I take some photos here because I think there are some differences where the screws are located in my vacuum cleaner.
из
Thank you. This is the best place to look after help to DIY. There's always someone who knows has been exploring how to figure it out.
из
Посмотреть содержание изображения:
Счет 0
2 Комментариев:
Here are the two extra parts. Some Roborock S7 screws to compare part sizes.
из
Lengths of screws 5 mm (2/8“), 8.5 mm, 13.5 mm and 30 mm.
из
Добавьте свой ответ
Riku Rinne буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 7
За последние 30 дней: 32
За все время: 381
