Руководства по ремонту и поддержке электрических и бензиновых аппаратов высокого давления, также известных как мойки высокого давления.
Brand new pressurer washer no pressure.
I bought a pressure washer 4 months ago when they went on sale at Sam's Club. It's a Troy Bilt 3400 psi 2.3 GPM gas model, model number TB3400PWXP. I finally went to use it for the first time today and it is not making pressure. It fired right up, I made sure the pump was primed first, then started it, and it makes no pressure. The stream of water coming out of the nozzle is the same if the engine is running or not. What is the most likely cause?
Update (11/12/25)
Troy Bilt TB3400PWXP
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hi @mauriceana70060
What is the colour of the spray tip being used.
Here's a list of the various tip colours that are used
Black - low pressure
Red - high pressure
Yellow - 15° fan pattern spray
Green - 25° fan pattern spray
White - 40° fan pattern spray
Был ли этот ответ полезен?
Счет 1
2 Комментариев:
Doesn't matter what tip, tried yellow and red. Same pressure when machine is running as when machine is off. It's just the pressure coming out of the hose.
из Поделиться
@mauriceana70060
If there are no leaks evident and since it's new, contact the manufacturer's customer service centre in your location and ask for a warranty repair or replacement. Sounds like a problem with the pump
из Поделиться
Добавьте свой ответ
Maurice Anastasio буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 11
За последние 30 дней: 38
За все время: 147
