Repair guides and support for computer monitors produced by Samsung.
Is there any way to repair this matrix? Samsung LH55EDD
The display panel displays horizontal lines. After disconnecting one part of the panel, half of it works perfectly, while the other half works terribly. I also tried covering the pins with flex tape, but the best results were still very poor. Is there anything else I can do about this?
Это хороший вопрос?
Счет 0
1 Комментарий
@amugus "display panel displays horizontal lines" what lines? Are you referring to your image #4? What's going on with that ribbon cable? which ribbon cable is that? You say "half of it works perfectly, while the other half works terribly" are you referring to top and bottom half or left and right half?
из
Добавить комментарий
1 ответ
Выбранное решение
I fixed it using piece of tape. Now horizontal lines are gone. I recommend watching this video: https://youtu.be/SbGAkRgaZhs
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
amug us буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 3
За всё время: 35
