1975-2011 (The picture is of a 2008 grand marquis)
How to stop my car from overheating?
I changed the radiator and coolant cap but now I think it’s a leak I don’t how to find and someone told me to change the thermostat but I just want to ask.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
The thermostat is the first thing to check,.if you can change it yourself remove it and put it in a pan of boiling water and see if it opens or you can run engine until it gets hot and give the upper lower hoses ,if.one is hot and other is cold there is the.answer and.you can take cap off cool and start it watching for flow after warm up. Best o luck
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Kailib Thornton буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 2
За последние 30 дней: 25
За всё время: 124
