How or can I fix the antenna?
I believe I messed up my antenna thinking it was a reset button now I don't get any signal at home pls help!!! (;
Это хороший вопрос?
Это хороший вопрос?
Becca, not sure where you thought it was a reset and what you did, but if you are talking about the main antenna, I would replace it. The part number is 1225-5461. I did a Google search on it and it seems a bit difficult to locate, so you may have to check closer, depending on your geographical location. They do show a few replacement antenna in Europe. Hope this helps, good luck.
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 1,213
