Repair guides and disassembly information for the 14-inch MacBook Pro released in October of 2021, featuring Apple-designed M1 Pro and M1 Max SoCs. Model A2442.
Runaway cursor and click after battery replacement
I replaced the battery on a 2021 MacbookPro. Now, I have functionality, but the cursor/trackpad will suddenly runaway, and/or click in rapid fashion. I have to use a key to stop it. I will recheck cables and connection tapes, but if anyone else has any ideas please let me know.
Это хороший вопрос?
Счет 0
2 Комментариев:
Try a SMC & PRAM reset and also check in the setting for Track Pad & Mouse click & tracking speeds.
из
Update: SMC gets reset automatically and PRAM I did. No change. I figured out it's not the trackpad but the cursor keys. The right and up keys are not working right. Up key gets activated. I cleaned them, checked the keyboard connection. Can't find anything.
из
Добавить комментарий
1 ответ
Sounds like the solvent got into the trackpad sensor area. See if an incandescent light. Can warm up the pad to evaporate the solved from within the trackpad. If that fails you may need to replace it. Some people forget to take out the trackpad when they do the Battery.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Thomas R буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 3
За всё время: 44
