Why my radio,distance lock door and the radiator fan stop
the radio ,distance lock door,the radiator fan stop and sometime the lighs on the bords when i put the ignition dont go fine.
Это хороший вопрос?
Это хороший вопрос?
This sounds like a really odd combination of symptoms, but they do share one common component - The Intelligent Power Module, which is located under the hood, on the driver's side, next to the relay box. If you have an intermittent problem, then maybe you have a loose connection here.
Another potential problem area is the ignition switch itself. There are at least 3 main circuits that feed through the switch and if there is a bad contact inside the switch, it is possible to have one or more circuits not working when the switch is in the "run" position.
Hope this helps,
BILL
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 486
