cant log in anymore
I was messing around i guess where i shouldnt have and now i cant log in so is there a way of getting in so i can change the things i messed up?
Это хороший вопрос?
Это хороший вопрос?
Almost none of the HP and Compaq consumer desktop computers do allow power-on passwords. Instead, they use a BIOS Lock Supervisor password and Windows Logon password. Follow Justin's advise for the Windows password, and if nothing else try to clear the CMOS password. For that, follow the steps on here. Hope this helps, good luck.
Был ли этот ответ полезен?
This was a work computer and needed a password to get in to do things..I knew the password but wanted to try and not have to log in via password is why I was messing with it, a nove at getting into the inner workings of the computer but will try and do your cmos password clearing, sorry for being so confusing. this is a HP compaq with Pentium 4 processor and windows xp professional(does this help at all?)?
Your computer starts up and what is the screen that you first see, the one with the log in?
Actually its the flash screen with options to use F9 or F10, ect then it goes to log in screen. I tried you trick about the bios but the pictures do not match my computer but i tried anyway but no luck. i greatly appreciate you helping me I am a novice when it comes ti the innner workings of a computer. Actuallu until this month I never took the cover off one so I do appreciate your patience with me...Thank You!!!
What does it tell you where F9 or F10 is going to take you? What are your menu choices?
You should be able to boot into safe mode and log into the Administrator Account and do a system restore. I am going to assume you are using Windows XP.
1. When you power up the computer start and keeping pressing F8 every second until you get to a menu that has boot options.
2. Choose Safe Mode
3. When it boots up choose the Administrator Account
4. When this opens up it will ask you either to continue to work in safe mode or restore your computer to a earlier time using system restore.
5. Choose the Yes or No that takes you to System Restore.
6. Follow the prompts and choose to restore your computer back to a date before you were messing around. I always do 2 weeks just to be safe. None of your files will be affected however if you have installed any new programs or updates they will need to be reinstalled.
Hope this helps!!!!
If you can't login your HP laptop password, you can try to guess the password if you have time, sometimes the password is as easy as 123456. But if that fails, you can aslo try the Windows password reset disk, it is a good method, too. You can even use a third party program, such as the SmartKey Windows Password Recovery or the Ophcrack.
when you face password screen then you click ctrl+alt+del button then the new window will apper your front & get the user name - Administrator & password - Blank and press enter button ok ........................
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 2,819
2 Комментариев
computer is password protected so o cant get into it at all, will the F8 thing work for sure?
из trekkiedude2000
It is the password to get into your computer, not your operating system i.e. Windows?
из oldturkey03
