The HP ProBook 440 G8 is a versatile business laptop featuring a 14-inch FHD display, powered by Intel's 11th Gen Core processors, and equipped with up to 32GB of RAM and a range of SSD storage options. It boasts advanced security features, robust connectivity options, and a sleek, lightweight design, making it ideal for professionals on the go.
Help HP Probook 440 G8 Blinking Light
Hi Everyone
I have a HP Probook 440, Motherboard dax8qamb8d0 rev-d, This laptop once connected only take 0,007 amp (see the picture bellow)
and the light start blinking (image bellow), I don't know what could be, maybe something with the BIOS I don't know. I hope you can help me.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
it usually indicates a hardware or power issue. First, perform a hard reset: unplug the charger, remove external devices, then hold the power button for 15–20 seconds. Reconnect the charger and try again. If the light keeps blinking, check the charging adapter and port for damage. Update or reset the BIOS if possible. Blinking patterns can also signal RAM or battery problems, so reseating memory (if accessible) may help. If the issue persists, contact HP support for diagnostics or repair.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Robinson Reyes буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 6
За последние 30 дней: 30
За всё время: 99
