Repair guides and disassembly information for air purifiers.
Fix the electric motor on my air purifier
Have a hunter tower air purifier..first use, it smelled when the fan ran..took it apart, opened electric motor and it looked fine..put it back in together and the motor won't turn now unless I give it a helping push..it also only turns at medium and high power, not low.
What could the issue be? It seems to rotate smoothly when turned off so I don't think friction is the issue
For reference, here are some images:
Pictures of the circuit board:
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Hi @ztwrhk3g6luccw6
What is the model number of the air purifier?
Fan motors usually have different value capacitors (may be all in the one can) connected in various configurations via the speed switch to control what speed the motor rotates at.
The capacitors also help the motor to overcome the initial inertia from the at rest position and to start to rotate.
Perhaps one is faulty.
Post an image of the control board etc in your question so it can be seen what components may be there. This is helpful if there's no service manual available online. Here's how to do this on ifixit. Добавление изображений к существующему вопросу
Был ли этот ответ полезен?
Счет 1
5 Комментариев:
Thanks for the inputs. I updated my post with the images. This is a Hunter Tower Air Purifier (HP670).
из
@ztwrhk3g6luccw6
Might be just shadows in the 1st image but the 2 capacitors near the green R1 resistor and the yellow component look like they got hot as there seems to be black scorch marks at their base.
If you turn over the board, you can see where the H M L connectors go to on the board by following the tracks that they're soldered to. H M L = high, medium low
из
@jayeff Thanks - I uploaded additional pictures of the circuit board. It appears it was just shadows. The capacitors, and other components visually look fine. I don't see any issues with them.
I wonder can I test these components with a multimeter?
из
@ztwrhk3g6luccw6
If your DMM has a capacitance test you can but they need to be disconnected/removed from the circuit board first.
You can also test them using the Ohmmeter function of a DMM as well but it is not so accurate.
Once they're removed formth eboard set the Ohmmeter to measure the highest resistance e.g. 20MOhms and then connect the meter to the capacitor legs.
The meter should show a moving resistance value which slows down.
This is the meter charging the capacitor. Once the meter has stopped or slowed to a crawl, revers the meter lead connections on the capacitor and it should discharge through the meter as shown on the meter.
If you measure short circuit i.e. 0.00 Ohms (try lowest resistance scale to confirm) or infinite Ohms (OL on meter perhaps) i.e. open circuit then the capacitor is faulty.
Be aware when remove the capacitor from the board as they appear to be the electrolytic type i.e. polarity dependent.
Take note of the markings on the can the -ve leg has a stripe down the side of can
из
@ztwrhk3g6luccw6
You could also test if the speed switch is OK by checking if there's a circuit between the H, M & L wires on the board and say and earth when the appropriate switch setting is selected e.g. press the low speed setting and check if there is a connection between the L and earth etc.
Not sure if there will be one as there's no schematic but you have to prove the the switch works as well as it determines which capacitor may be connected to the motor to affect the speed, or if not a capacitor the voltage etc.
из
Добавьте свой ответ
Retro-Tech буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 5
За последние 30 дней: 29
За всё время: 219
