Используйте эти подробные руководства по ремонту, решения для устранения неполадок и другую полезную информацию, чтобы ваш HP Elitebook 745 G6 всегда работал исправно.
Прокрутите эту тему, чтобы найти подходящее место для этого комментария. Затем нажмите "Прикрепить комментарий к этому сообщению", чтобы переместить его.
First, the swollen battery — that needs to be removed and replaced.
A “fat” battery is not safe to use. Don’t try to charge it again.
You can test the laptop with the battery removed and only the charger connected.
Now about the black screen:
Since the keyboard lights turn on, the laptop is getting power. That usually means it’s not a total power failure.
Try to do these things:
Power the laptop on and shine a flashlight directly at the screen from very close range and look carefully from different angles.
If you can see a faint image in the background, the backlight (or the LCD panel itself) has likely failed.
If there is absolutely no image at all, try to connect an external monitor or a TV with HDMI
If the external display shows an image, the problem is most likely the internal screen or the display cable.
If none of those worked, try to carefully open the back cover, and remove the RAM for a minute, then put it back in (you have to hear the click sound when it pops up into its place.
