Первый автомобиль Volvo с передним приводом, экспортировавшийся в Северную Америку
How do I change the blower motor resistor
blower motor wont work
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Since you didn't specify what year your 850 is, I randomly picked the 1995 model. This diagram shows you the location of the blower motor resistor.
NOTE: H2 is the Fan Resistor.
This page gives service information, but also notes that it's only applicable to manual climate control; if you have the automatic climate control system this may not be correct for your car.
Blower Motor Resistor: Service and Repair — 1995 Volvo 850 L5-2.4L VIN 55 B5254S Service Manual - Operation CHARM
If your car has the ECC, or Electronic Climate Control system, then it doesn't have a blower motor resistor. This page describes the operation of the blower motor for that system.
Control Module HVAC: Description and Operation — 1995 Volvo 850 L5-2.4L VIN 55 B5254S Service Manual - Operation CHARM
It looks like the information is the same for all the years they list, but you can manually navigate to the correct year for your car to verify that.
Был ли этот ответ полезен?
Счет 2
1 Комментарий:
@michaelmur36338 besides the excellent answer provider by my colleague, you can also use this manual Volvo 850 1992 1996 Starting on page 59 it explains how to work on the HVAC system for the Volvo 850. You now can also find a service manual that is searchable etc. for the same vehicle under the Documents Tab on this page 1993-1997 Volvo 850
из
Добавьте свой ответ
michael murphy буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 5
За последние 30 дней: 21
За всё время: 135
