My lens cap broke If I put gasoline glue on it, it will stick?
Это хороший вопрос?
Это хороший вопрос?
@grykbx7xmuhqfpy not sure which lens cap you are referring to, but gasoline will most likely melt and destroy your lens cap. HDPE plastics are pretty much the only ones safe to use with gasoline. Do NOT use gasoline for your lens cap!
Был ли этот ответ полезен?
Ok thanks(I'm referring to the plastic around the lens.)
@grykbx7xmuhqfpy Gasoline would definitely not be a good choice :-)
За последние 24 часов: 2
За последние 7 дней: 7
За последние 30 дней: 42
За все время: 306
1 Комментарий
Our confusion comes from your use of the term "gasoline glue". Are you referring to a type of adhesive used to seal leaking gas tanks? If so, that probably wouldn't be my first choice unless you don't have any other glue available.
We're talking about a pair of sunglasses, right? What exactly do you mean by "lens cap"? Are you talking about the frame that holds the lens in place? How is it broken; did it come apart or is the plastic snapped? A picture might help if you can add one to your question; this guide will help.
Добавление изображений к существующему вопросу
из Jerry Wheeler Поделиться
