Информация по ремонту и диагностике телевизора Vizio E422AR. Это 40-дюймовый HD-телевизор с ЖК-экраном.
Why did the sound go out
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
No Sound Troubleshooting Tips
  1. Check Volume & Mute Settings
    • Make sure the TV volume isn’t muted or set too low.
    • Verify the remote control is working properly (try the physical buttons on the TV too).
  2. Input Source Settings
    • Confirm the correct input is selected (HDMI, AV, Component, etc.).
    • If using HDMI, try a different port or cable to rule out a bad connection.
  3. Audio Output Settings
    • Go into the TV’s audio menu and check if the speakers are set to “On.”
    • If using external speakers or a soundbar, ensure the TV is set to output audio through the correct port (optical, RCA, etc.).
  4. External Speaker Jack
    • The E422AR has an optical audio output and RCA stereo outputs.
    • If connected to external speakers, make sure cables are secure and the external device is powered on.
  5. Firmware Updates
    • Check if a firmware update is available through VIZIO’s support site. Updates can sometimes fix audio bugs.
  6. Factory Reset
    • If settings got corrupted, perform a factory reset from the TV’s menu.
    • This will restore default audio settings and clear glitches.
  7. Test with Different Devices
  8. Plug in a DVD player, game console, or streaming stick to see if the issue is with the TV or the original source device.
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Eric Hall буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 7
За всё время: 65
