The battery cap is corroded on. How can it be removed?
I picked up the apple wireless keyboard from a friend who wasn't using it. I went to put batteries in it and found out that it was stuck.
Then I:
- Tried a basic flathead
- Tapped around the head with a small hammer to see if it would unseal
- Attempted a vice and nickel method--I now have a torqued nickel.
So far no direct access method has worked.
I also read the Batteries Corroded & stuck thread n here.. That allowed me to know there was a panel on the back. My KB is a little different, the panel is more in the middle. I opened it up and see there is a battery--so I'm nearly sure it's a corroded battery that has leaked onto the aluminum screw and caused all of this.
Anyone have ideas on how to solve this?
Это хороший вопрос?
1 Комментарий
I tried baking soda, vinegar, boiling water and a heat gun, nothing would budge my stuck Apple Keyboard battery door. I finally got out my dremel tool and made a small 1/4" slit on the underside of the battery compartment by the battery cover. I was able to turn and get the battery cover off at that point.
My AA batteries were stuck at that point but I followed a YouTube video and removed the control board (easy) which allowed me to punch out the batteries.
из Michael Jones
