MacBook fell ,whitescreen ,could it be fixed?
the macbook fell , it starts up but the screen is white ..can it be fixed without any part change?
Это хороший вопрос?
Это хороший вопрос?
In my experience, a white screen indicates a faulty hard drive. Try starting up from your system installation disk, if you get a screen, run Disk Utilities and see if you can repair the hard drive.
Был ли этот ответ полезен?
Try to push the RAMs firmly in case they moved a bit out from the slots at its fall. This would solve the issue if concerned to RAMs.
If your white screen also shows a blinking question mark sign, open the case, try locating HD and push the HD cable to its slot properly both to the HD itself and to the logic board. Let me know if that doesn't solve your issue. Try the first instruction first.
that means i should open the unit ?
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 232
