PSP not charging but working fine with a charged baterry inside.
My childhood PSP broke :(. The problem is that it does not charge and only works if i put in a charged battery in. I tried using both charging ports to no succsess. I opened it up and checked the continuity of the main power fuse marked TB with a multimeter, it was blown. So i shorted it and the console still would not charge. After that i tried putting in a charged battery and it worked so shorting the fuse did not cause any damage.i tried checking other fuses for continuity based on https://www.komstation.com/guides/psp-fu... but i found some of the fuses were poorly marked, every fuse that i found and checked worked. I do not know what the problem could be.
Someone please help. Thank you if you will take a look into my problem.
Это хороший вопрос?
Hi!
Most likely motherboard related… So, you have replaced the charge port, correct? What does it say when you check “battery information” while charging it? Thanks!
из koppie007 Поделиться
I have not replaced the charge port i know it works because when i try to charge the console i measure 5V between the two ends of the TB fuse.
из Aleksander Поделиться
Alright. That is good. What does it say when you check > settings > battery information? Thank you
