bottom half of touch screen not working after replacement
swapped out the digitizer and now the bottom icons do not work
Это хороший вопрос?
Оценка -1
Добавить комментарий
2 Ответов
Наиболее полезный ответ
It sounds like either a faulty digitizer or maybe something might have gotten unplugged when you put it back together. I would try to pull it back apart and make sure that everything is connected properly and if you still have an issue, then I would say that it is a faulty digitizer.
Был ли этот ответ полезен?
Оценка 1
Do as Michael Stoffer writes, but also make sure contacts are clean and nothing is in the connector port.
Оценка 1
Добавьте свой ответ
sheldon будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 1,460
