The display on my iPod is blurred?
for a while i had problems with my ipod. half of the screen was unresponsive to any touch but i left it . after being cracked & quickly fixed at a non-apple store it had a little opening gap between the upper left side. i was messing with it & squeezed it down pretty hard & when it got back on the screen was more as fizzed out like a tv screen. the side that wasnt working is still unresponsive to touch & i have the additional problem to the color & display. any one know how much it could cost it be fixed? or how i can?
https://discussions.apple.com/message/19...
Это хороший вопрос?
по рейтингу 1
Добавить комментарий
2 Ответов
Наиболее полезный ответ
sarah, it sure looks like you need a new display assembly. The unresponsiveness is from a broken digitizer circuit and the distorted image is a broken LCD. Check here for the guides. Hope this helps, good luck.
Был ли этот ответ полезен?
по рейтингу 2
Had a similar issue with mine, the display was flickering regardless of pressure on the back. i swapped the screen myself for under 60 bucks with no issues sense. I got mine from here.
по рейтингу 1
Добавьте свой ответ
sarah будет вечно благодарен.
Просмотр статистики:
За 24 часа: 0
За 7 дней: 2
За 30 дней: 6
За всё время: 1,907
