Why iBook won't start while having a disc in drive?
My G4 1.2 ghz iBook 12" starts but has no video and a disc stuck in the drive. I've tried the touch pad while booting and apple option o f command but nothing works to eject the disc. It started all of sudden when we tried to start it up. The screen lights but dim and nothing else appears on the screen and it won't shut down without removing the battery.
Это хороший вопрос?
Оценка -1
Добавить комментарий
1 ответ
Выбранное решение
Start it up in Target mode by holding down the "T" key. You need to be connected to another Mac via a Firewire cable to do this. The hard drive icon should appear on the monitor of the second mac. You can then run disk utilities on it. What kind of disk is stuck?
Был ли этот ответ полезен?
Оценка 1
3 Комментариев:
Thanks I'll try that. It has a picture dvd in it. I'll try this this evening and let you know how it worked for me.
из
Must have worked as we didn't here back from you.
из
agreed +
из
Добавьте свой ответ
Sonny будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 815
