iPod Classic 6th Generation. Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
903вопросов Показать все
Making strange noise & won't restore?
I have a ipod classic 120 gbs it's making a strange noise & then when i try to restore it NOTHING. and it stays on the apple logo screen only PLEASE help :(
Это хороший вопрос?
Оценка 3
1 Комментарий
Same here It's annoying
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
Dzeni, the only thing that I can think off, which could be making strange noises, is the hard drive. Try and place your iPod into diagnostic mode. Check on here how to do that. Or you can try and place it in disk mode, and see if you can access the drive. This will tell you how to do that. If you can access your drive, reformat it and see if that makes a difference. From your short description, I would say that you will need a new hard drive. The guides to work on your iPod are here and the hard drive is available right here as well as many other places. Hope this helps, good luck.
iPod Classic 120 GB Hard Drive Изображение
Продукт
$52.99
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Dzeni будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 5
За последние 30 дней: 16
За всё время: 18,143
