Steps you should take before advanced soldering techniques.
1. Hold Power and Home Button for Hard Reset
2. Unplug battery cable, reconnect, power on
3. Check your LCD connector for damage, dirt, metal, lint, etc
a. Check LCD connector on the motherboard for same
4. Curse yourself for not unplugging the battery while working on it
5. Multi meter the green traces that YoloRepair pointed out
6. Perform a fuse replacement, or a jump. - Recommended you seek pro help, because this type of repair requires a stereoscope and a extremely steady hand with soldering skills.
Making Jumper Steps
1. Make sure it's that part - http://i39.tinypic.com/3130ry8.jpg
2. Give yourself access to both side, I made small cut on shield
3. Remove blown fuse, replace or jump. I chose jump - http://i44.tinypic.com/2lbno5k.jpg
4. Test - WOOHOO! Thanks YoloRepair <3 - http://i39.tinypic.com/2924cyb.jpg
5. Clean excess flux and leave repair area in best shape possible - http://i40.tinypic.com/mbtok3.jpg
6. Test everything again, close it, and get sigh of relief.
7. Thank YoloRepair once more.
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
3
Отмена
Scroll through this thread to find the appropriate place for this comment. Then, click "Attach comment to this post" to move it.
15 Комментариев
Do you see picture just no backlight?
из Alfy
If I push the powerbutton, the Apple logo apears, but no backlite. Just seen this with the screen turned up into the sun.
из tuningdude
I need a clear picture of the fuse that must be jumped, or how to use the Bare Conductive Pen to create a jump across the fuse to "what?".
из Chester Henry
Replaced touch screen. Now have no picture. What fuse do in have to bypass. Can you post a picture or video. Thanks for the help
из Nick
i have the same problem ho can i fix it can u please help me
из glena
Показать 10 больше комментариев
