1 Диаграмма
Модели
CAP2000P
Background
The Bostitch Air Compressor CAP2000P is an electric air compressor that was first introduced in August 2010. It has a power source of 120 volts and a motor power of 2 horsepower. The air compressor is equipped with a 6-gallon capacity tank, and its dimensions are 17 x 20.5 x 17 inches. It weighs approximately 38 pounds. The air flow capacity of this compressor is 2.8 Cubic Feet Per Minute and it is capable of a maximum operating pressure of 150 PSI. The noise level of the compressor is recorded to be 78.7 dB.
The Bostitch CAP2000P is designed for portability and convenient usage. It is assembled with an oil-free pump that does not require any maintenance. The air compressor is powered by an electric motor that has thermal overload protection. The compressor's structure includes an impact-resistant composite body and shroud that shields the gauges and other critical components. It is also equipped with a regulator, a factory-installed pneumatic quick coupler, and a ball drain valve to simplify tank drainage. The unit's design is compact and portable, contributing to its weight of just 38 pounds.
Technical Specifications
- Power source: Electric
- Voltage: 120 Volts
- Maximum power: 2 Horsepower
- Capacity: 6 Gallons
- Dimensions: 17 x 20.5 x 17 inches
- Weight: 38 pounds
- Air flow capacity: 2.8 Cubic Feet Per Minute
- Motor horsepower: 2 Horsepower
- Maximum operating pressure: 150 PSI
- Noise level: 78.7 dB
Warranty
The Bostitch Air Compressor CAP2000P comes with a limited warranty that lasts for one year. This warranty covers any defects that can be attributed to the materials used in the manufacturing process or the workmanship. In order to claim the warranty, you need to be the original purchaser of the product and you must have proof of this purchase.
