1 Диаграмма
Popular Forum Questions
СпроситьТам нет никаких вопросов. Будьте первым,ask задайте вопрос!
Background and Identification
The Diamabrush model 941601202 is a 25-grit cutting tool that removes coating and profiles on concrete surfaces. It is designed to be used with standard battery-powered or 110-Volt cleaning equipment like automatic scrubbers and single-disc flooring machines. The cutting tool comes with a universal clutch plate (NP9200) and a 1.5-inch riser (ZRPLR150). The clutch plate and riser are required to attach the Diamabrush concrete prep tool to universal scrubbers and flooring machines.
The Diamabrush model 941601202 is advertised to prepare up to 30,000 square feet of concrete. The Diamabrush Concrete PrepPlus tool is designed to last up to 50,000 square feet. It uses diamonds as an abrasive material on a 16-inch-diameter wheel. The 25 diamond grit is bonded to a metallic backing and assembled to flexible steel spring blades. It is designed to prepare floors for applications of paints, epoxies, or stains and will remove a thin layer of paint or epoxy.
Flexible Diamabrush blades are designed to work with machines below 115 pounds in weight for a single disk or auto scrubbers with less than 115 total pounds of pad pressure. The 25 grit tool is recommended for very rough or uneven floors and is designed to be the first step to smooth concrete floors.
Technical Specifications
Dimensions:
- Product Height (in.): 4
- Product Length (in.): 16
- Product Width (in.): 16
Details:
- Abrasive Material: Diamond
- Application: Heavy Duty
- Arbor Size: 16"
- Backing Material: Resin
- Grit: 24
- Power Tool Accessory Type: Sanding/Grinding/Polishing Accessory
- Sanding Grade: Coarse
- Sanding, Grinding and Polishing Accessory Type: Diamond Grinding Wheels
- Tools Product Type: Power Tool
- Wheel Diameter (in.): 16"
