3 Диаграммы
Popular Forum Questions
СпроситьТам нет никаких вопросов. Будьте первым,ask задайте вопрос!
Документы
Модели
GEC01
Background
The Makita GEC01Z is a product designed for cutting various masonry and metal materials. It is a brushless 14" power cutter that is capable of making cuts up to 5" deep in one pass. The power cutter is powered by two 40V max XGT Lithium-Ion batteries which eliminates the hassles of engine pull starts and managing proper fuel/oil mixing. The product features such as integrated anti-vibration mechanism, electric brake, and overload protection are designed to enhance the user's experience and the tool's efficiency.
The Makita GEC01Z is equipped with an integrated water delivery system which aids in concrete cutting applications, and an adjustable blade guard for facilitating cutting in different wall zones. It also features a built-in L.E.D. light for increased visibility in the cutting area, and an overload indicator to alert the user of excessive battery power draw during heavy loads. The product is designed with a rubberized front handle that can be held in multiple positions for increased comfort at various cutting orientations. It is also built with a belt-drive design that provides smoother operation with lower vibration.
The Makita GEC01Z is a cordless power cutter with a brushless motor, which offers a no-load speed of 5,300 RPM. The product dimensions are a wheel diameter of 14", a maximum cutting depth of 5", and an overall length of 31". The net weight with battery is 31.1 lbs, and the shipping weight is 31.62 lbs.
Technical Specifications
- Battery: 40V max XGT Lithium-Ion
- No Load Speed: 5,300 RPM
- Wheel Diameter: 14"
- Max. Cutting Depth: 5"
- Arbor w/ Adaptor: 20mm/1" adaptor
- Lock-Off Switch: Yes
- Electric Brake: Yes
- Bind-Up Control: Yes
- Vibration (m/s2): 2.5
- Sound Pressure: 109 dB(A)
- Overall Length: 31"
- Net Weight (with battery): 31.1 lbs.
- Shipping Weight: 31.62 lbs.
- Power Type: Cordless
- Motor Type: Brushless
More Information
Makita GEC01 Cordless Power Cutter Instruction Manual
