Ответов (6) 2 Оценка |
Vertical Lines on my Samsung LN46c630 LCD tv |
Ответов (1) 1 Оценка |
Sound is heard but not seen |
Ответов (1) 0 Оценка |
Where are the buttons to change channels, turn on and off |
Background and Identification
The LN46C630K1FXZA (the name just rolls off your tongue) is an LCD television released by Samsung in 2010. It has a 46-inch screen with a resolution of 1920x1080 pixels. Generically, this TV is referred to in documentation by the shorter model number “LN46C630K1F” or the simple description of “the 46-inch model in the C630 series.” You can identify this specific TV by looking for a sticker containing the model number “LN46C630K1Fxxx” (the xxx can be any letters/numbers) on the right side or back of the device. See this Samsung support article for pictures of this sticker on a TV.
This Samsung TV can accept digital and analog video signals as well as broadcast television stations transmitted over the air. Attach an antenna to the coaxial port on the back of the device to pick up digital TV broadcasts. The selection of ports on the LN46C630K1F include four HDMI ports and two component/composite video ports for connecting to older devices. You can use the two USB ports on the TV to power other devices or to update the firmware on the set.
You can connect the LN46C630K1F to the internet via an Ethernet jack on the back of the device or by using a USB Wi-Fi adapter in one of the aforementioned ports. You can remove the included stand and mount the TV to a wall or arm using a 400x400 mm VESA mount and M8 screws. See the Samsung manual (or support page for manuals in other languages) for more details on this procedure.
Technical Specifications
Display
- 45.9 inches (116.6 cm) on the diagonal
- 1920x1080 pixels
Audio
- Two 10 W speakers
Connections
- Four HDMI ports (one port specifically for DVI to HDMI adapters)
- Two component video/audio inputs (one shared with composite)
- Two composite video/audio inputs (one shared with component)
- VGA video input
- 3.5 mm stereo audio jack (for audio alongside VGA video or DVI to HDMI adapter)
- Ethernet LAN port
- Coaxial antenna connector
- Two USB ports
- 3.5 mm stereo audio output jack
- Digital optical audio output (TOSLINK)
Dimensions
- Without stand: 43.7” x 26.5” x 3.2” (111.0 cm x 67.3 cm x 8.1 cm)
- With stand: 43.7” x 29.0” x 10.8” (111.0cm x 73.7 cm x 27.4 cm)
Additional Information
Samsung C630 series official support page
