1 ответ -1 Оценка |
Why are these HDD connectors not the same? |
GENERAL
Packaged Quantity 1
System Type Notebook
Operating System Microsoft Windows XP Home Edition
Notebook type Thin-and-light (4-6 lbs.)
ManufacturerToshiba
PROCESSOR / CHIPSET
Cache L2 - 1 MB
Front Side Bus 400 MHz
Chipset ATI Radeon Xpress 200M
Features Execute Disable Bit capability
MEMORY
Max RAM Supported 2 GB
Technology DDR2 SDRAM
Speed 533 MHz / PC2-4200
Form Factor SO DIMM 200-pin
Slots Qty 2
Empty Slots 1
STORAGE
Hard Drive 60 GB HDD / 5400 rpm
Optical Drive CD-RW / DVD-ROM combo - fixed
Read Speed 24x (CD) / 8x (DVD)
Write Speed 24x
Rewrite Speed 24x
Optical Drive (2nd) none
Type portable
DISPLAY
Resolution 1280 x 768 ( WXGA )
Widescreen Yes
Features TruBrite
ENVIRONMENTAL PARAMETERS
Min Operating Temperature 41 °F
Max Operating Temperature 95 °F
Humidity Range Operating 20 - 80%
AUDIO & VIDEO
Graphics Processor ATI Radeon Xpress 200M
Memory Allocation Technology shared video memory (UMA)
Max Allocated RAM Size 64 MB
Sound Stereo speakers
Codec Realtek ALC250
Compliant Standards DirectSound
Audio Features SRS WOW
INPUT
Type touchpad
COMMUNICATIONS
Wireless 802.11b/g
Network Interface 10/100 Ethernet
MODEM
Max Transfer Rate 56 Kbps
BATTERY
Capacity 2000 mAh
Run Time 2.1 sec
AC ADAPTER
Input AC 120/230 V ( 50/60 Hz )
Output 65 Watt , 19 V , 3.42 A
CONNECTIONS & EXPANSION
Slots 2 x memory ( 1 free )
1 x CardBus ( 1 free )
Interfaces 1 x display / video - S-video output
1 x display / video - VGA - 15 pin HD D-Sub (HD-15)
1 x microphone - input - mini-phone 3.5 mm
1 x headphones - output - mini-phone stereo 3.5 mm
3 x Hi-Speed USB - 4 pin USB Type A
1 x modem - phone line - RJ-11
1 x network - Ethernet 10Base-T/100Base-TX - RJ-45
SOFTWARE
Software Included AOL Online (90 days trial)
MISCELLANEOUS
Color mist gray
Features administrator password
Compliant Standards VESA DPMS
DIMENSIONS & WEIGHT
Width 13.5 in
Depth 9.5 in
Height 1.5 in
Weight 5.1 lbs
GENERAL
ManufacturerToshiba
