iPad Mini 2 Teardown
11 Ответов 7 Оценка |
White Vertical Lines on the screen |
10 Ответов 12 Оценка |
Ipad not turning on; stuck in charging symbol during ios 11 update |
6 Ответов 5 Оценка |
Will the LCD from iPad mini 1 work on iPad mini 2? |
2 Ответов 1 Оценка |
I accidently tore a cable or flex that was glued to the glass screen |
Запчасти
Инструменты
Вот некоторые основные инструменты, используемые для работы на данном устройстве. Вам, возможно, не понадобиться каждый инструмент для каждой процедуры.
Background and Identification
Slightly thicker and heavier than the previous generation of iPad Mini, the iPad Mini 2 (iPad mini Retina) shares many of the iPad Air's specifications.
The iPad mini 2 can be identified by its model number, found on the lower rear case.
- Wi-Fi: A1489
- Wi-Fi/Cellular: A1490
- China: A1491
Specifications
Announce date: October 22, 2013
Color display: 7.9-inch Retina Display
Processor: Dual-core Apple A7 processor
Resolution: 2048-by-1536 resolution at 326 pixels per inch
Storage: 16, 32, 64 or 128 GB flash memory
Wireless: Wi-Fi (802.11a/b/g/n); dual channel (2.4GHz and 5GHz) and MIMO, with Bluetooth 4.0 and optional LTE.
Battery: Built-in 23.8-watt-hour rechargeable lithium-polymer battery (Up to 10 hours of use)
Weight: 0.73 pound (331 g)
Dimensions: 7.87 inches (200 mm) x 5.3 inches (135 mm) x 0.3 inch (7.5 mm)
Troubleshooting
- Diagnose and repair screen backlight issues with our iDevice Backlight Troubleshooting Page.
