1 ответ 0 Оценка |
My phone won't turn on |
7 Ответов 15 Оценка |
camera problem of lenovovibe k5 |
1 ответ 0 Оценка |
not vibrating, battery draining so fast |
1 ответ 0 Оценка |
How to solve the contacts is busy. Please try later |
Background and Identification
The Lenovo Vibe K5 is an Android smartphone released by Lenovo in June 2016. The Lenovo Vibe K5 includes models A6020a40, A6020a41, A6020l36, and A6020l37 and is available in gold and silver body colors.
The Lenovo Vibe K5 features a 5.0-inch capacitive touchscreen display with a resolution of 720 by 1280 pixels and a screen-to-body ratio of 68.4 percent. It includes a glass front, an aluminum back, and an aluminum frame. The Lenovo Vibe K5 includes dual SIM capabilities, meaning it can hold two Micro-SIM cards and operate with one while the other is on standby. The phone was released with 16 GB of internal storage and 2 GB of RAM.
The Lenovo Vibe K5 features a 13-megapixel main camera and a 5-megapixel front-facing camera. It includes a 2750 mAh removable battery, meaning that the battery’s adhesive is not permanent, making repair and replacement easier than for non-removable batteries.
The Lenovo Vibe K5 includes the name “Lenovo” in the upper center of the phone’s backing. The phone includes Android’s three-button navigation system, which includes a “back” button (indicated with an arrow on the left side of the bottom bezel), a “home” button in the center of the phone’s bottom bezel, and a “show-all-open-applications” button (indicated by a rectangle on the right side of the phone’s bottom bezel).
Technical Specifications
Models: A6020a40, A6020a41, A6020l36, A6020l37
Release date: June 2016
Body:
- Dimensions and Weight: 142 x 71 x 8 mm (5.59 x 2.80 x 0.31 in), 142 g (5.01 oz)
- Build: Glass front, aluminum/plastic back, aluminum frame
- SIM: Dual SIM (Micro-SIM, dual stand-by)
Display:
- Type: IPS LCD capacitive touchscreen, 16M colors
- Size: 5.0 inches, 68.9 cm2 (~68.4% screen-to-body ratio)
- Resolution: 720 x 1280 pixels, 16:9 ratio (~294 ppi density)
Platform:
- OS: Android 5.1 (Lollipop)
- Chipset: Qualcomm MSM8929 Snapdragon 415 (28 nm)
- CPU: Octa-core (4x1.5 GHz Cortex-A53 & 4x1.2 GHz Cortex-A53)
- GPU: Adreno 405
Memory:
- Card slot: microSDHC (dedicated slot)
- Internal: 16GB 2GB RAM
- eMMC 4.5
Main Camera:
- Single: 13 MP, f/2.2, AF
- Features: LED flash, HDR, panorama
- Video: 1080p@30fps
Selfie Camera:
- Single: 5 MP, f/2.8
Sound:
- Loudspeaker: Yes, with stereo speakers
- 3.5 mm jack: Yes
Communications:
- WLAN: Wi-Fi 802.11 b/g/n, hotspot
- Bluetooth: 4.1, A2DP, LE
- GPS: Yes, with A-GPS
- Radio: FM radio
- USB: MicroUSB 2.0, USB On-The-Go
Features:
- Sensors: Accelerometer, proximity
Battery:
- Type: Li-Ion 2750 mAh, removable
Miscellaneous:
- Colors: Champagne Gold, Platinum Silver
