1 ответ 0 Оценка |
Missing knob fader for the k.o.2 |
Background and Identification
The EP–133 K.O. II from the company teenage engineering is a sampler, sequencer and composer. It can record sounds, sequence samples and loops, tweak and automate filter, pitch and effects. It’s the big brother of the known pocket-sized predecessor PO-33 K.O!
Technical Specifications
- Dimensions: 240 mm x 176 mm x 16 mm
- Built-in mic and speaker
- 6 stereo voices / 12 mono
- 64 MB memory, or 999 sample slots
- 6 built-in master FX and 12 punch-in FX
- Pressure sensitive keys and multifunctional fader
- Sampling frequency: 46 kHz / 16-bit
- 1x stereo in/out, sync in/out, midi in/out and USB-C
- Powered by 4x AAA batteries, or via USB-C
- Stereo Line input
- 24 bit
- SNR: 96 dBA
- Impedance: 6.5 kOhm
- Analog gain: 0 - 12 dB
- Max level: 8 dBu, 2.0 Vrms
- Stereo Headphone/Line Output:
- 24 bit
- SNR: 98 dBA
- Max level: 5 dBu, 1.4 Vrms
- MIDI input
- MMA compliant pinout (type A)
- opto-coupled
- MIDI output
- Voltage: 3.3 V
- Sync output
- TIP: Sync 8th, 16th, 24 ppqn
- RING: Start/Stop
- Voltage: 3.3 V
- Sync input
- RING: Start/Stop
- Voltage: 3.3 V
- Max level: 10 V
- Internal clock/sequencer resolution/step resolution
- 96 ticks (ppqn)
Additional Information
- Official product page: EP-133
- Official user guide: EP-133 user guide
- Downloads for operating systems: EP–133 OS updates
