iPhone 6 Logic Board Replacement
Выберете то, что вам нужно
  1. iPhone 6 Logic Board Replacement, Pentalobe Screws: шаг 1, изображение 1 из 1
    • Before disassembling your iPhone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.6 mm-long P2 Pentalobe screws next to the Lightning connector.
  2. iPhone 6 Logic Board Replacement, Anti-Clamp instructions: шаг 2, изображение 1 из 3 iPhone 6 Logic Board Replacement, Anti-Clamp instructions: шаг 2, изображение 2 из 3 iPhone 6 Logic Board Replacement, Anti-Clamp instructions: шаг 2, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Anti-Clamp
    $24.95
    Купить
    • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  3. iPhone 6 Logic Board Replacement: шаг 3, изображение 1 из 3 iPhone 6 Logic Board Replacement: шаг 3, изображение 2 из 3 iPhone 6 Logic Board Replacement: шаг 3, изображение 3 из 3
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait a few seconds between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  4. iPhone 6 Logic Board Replacement, Manual Opening Procedure: шаг 4, изображение 1 из 1
    Anti-Clamp
    $24.95
    Купить
    • If you don't have an Anti-Clamp, use a single suction cup to lift the front panel:
    • Press a suction cup onto the screen, just above the home button.
    • Be sure the cup is pressed securely onto the screen to get a tight seal.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
  5. iPhone 6 Logic Board Replacement: шаг 5, изображение 1 из 1
    • While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
    • Take your time and apply firm, constant force. The display assembly is a much tighter fit than most devices.
    • Using a plastic opening tool, begin to gently pry the rear case down, away from the display assembly, while continuing to pull up with the suction cup.
    • There are several clips holding the front panel assembly to the rear case, so you may need to use a combination of the suction cup and plastic opening tool to free the front panel assembly.
  6. iPhone 6 Logic Board Replacement: шаг 6, изображение 1 из 2 iPhone 6 Logic Board Replacement: шаг 6, изображение 2 из 2
    • Pull the plastic nub to release the vacuum seal on the suction cup.
    • Remove the suction cup from the display assembly.
  7. iPhone 6 Logic Board Replacement, Opening up the phone: шаг 7, изображение 1 из 3 iPhone 6 Logic Board Replacement, Opening up the phone: шаг 7, изображение 2 из 3 iPhone 6 Logic Board Replacement, Opening up the phone: шаг 7, изображение 3 из 3
    • Open the iPhone by swinging the home button end of the front panel assembly away from the rear case, using the top of the phone as a hinge.
    • Several clips along the top edge of the front panel form a partial hinge.
    • During reassembly, align the clips just below the top edge of the rear case. Then, slide the front panel upward until its top edge is flush with that of the rear case.
  8. iPhone 6 Logic Board Replacement: шаг 8, изображение 1 из 3 iPhone 6 Logic Board Replacement: шаг 8, изображение 2 из 3 iPhone 6 Logic Board Replacement: шаг 8, изображение 3 из 3
    • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
    • In a pinch, an unopened canned beverage works well for this.
    • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
  9. iPhone 6 Logic Board Replacement, Removing the battery connector bracket screws: шаг 9, изображение 1 из 1
    Magnetic Project Mat
    $19.95
    Купить
    • Remove the following Phillips screws from the battery connector bracket:
    • One 2.2 mm screw
    • One 3.2 mm screw
    • During your repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your phone.
  10. iPhone 6 Logic Board Replacement: шаг 10, изображение 1 из 1
    • Remove the metal battery connector bracket from the iPhone.
  11. iPhone 6 Logic Board Replacement, Disconnecting the battery connector: шаг 11, изображение 1 из 1
    • Use a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
    • Take care to only pry up on the battery connector, and not the socket on the logic board. If you pry up on the logic board socket, you may break the connector entirely.
  12. iPhone 6 Logic Board Replacement, Removing the front panel assembly cable bracket screws: шаг 12, изображение 1 из 1
    • Remove the following five Phillips screws securing the front panel assembly cable bracket:
    • Three 1.2 mm screws
    • One 1.7 mm screw
    • One 3.1 mm screw
    • Incorrect placement of these screws during reassembly will cause permanent damage to your iPhone's logic board.
  13. iPhone 6 Logic Board Replacement: шаг 13, изображение 1 из 1
    • Remove the front panel assembly cable bracket from the logic board.
  14. iPhone 6 Logic Board Replacement: шаг 14, изображение 1 из 2 iPhone 6 Logic Board Replacement: шаг 14, изображение 2 из 2
    • In the next four steps, take care to pry up only on the cable connectors, and not on their sockets on the logic board.
    • Use a spudger or a fingernail to disconnect the front-facing camera and sensor cable connector.
  15. iPhone 6 Logic Board Replacement: шаг 15, изображение 1 из 2 iPhone 6 Logic Board Replacement: шаг 15, изображение 2 из 2
    • Use a spudger or a fingernail to disconnect the home button cable connector.
  16. iPhone 6 Logic Board Replacement: шаг 16, изображение 1 из 2 iPhone 6 Logic Board Replacement: шаг 16, изображение 2 из 2
    • Make sure the battery is disconnected before you disconnect or reconnect the cable in this step.
    • Use a spudger or a fingernail to disconnect the display data cable connector.
    • When reassembling your phone, the display data cable may pop off its connector. This can result in white lines or a blank screen when powering your phone back on. If that happens, simply reconnect the cable and power cycle your phone. The best way to power cycle your phone is to disconnect and reconnect the battery connector.
  17. iPhone 6 Logic Board Replacement: шаг 17, изображение 1 из 2 iPhone 6 Logic Board Replacement: шаг 17, изображение 2 из 2
    • Use the flat end of a spudger to disconnect the digitizer cable connector.
    • When reconnecting the digitizer cable, do not press the center of the connector. Press one end of the connector, then press the opposite end. Pressing in the center of the connector can bend the component and cause digitizer damage.
  18. iPhone 6 Logic Board Replacement, Separating front panel assembly and rear case: шаг 18, изображение 1 из 1
    • Remove the front panel assembly from the rear case.
  19. iPhone 6 Logic Board Replacement, SIM Card: шаг 19, изображение 1 из 2 iPhone 6 Logic Board Replacement, SIM Card: шаг 19, изображение 2 из 2
    • Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray.
    • Press to eject the tray.
    • This may require a significant amount of force.
  20. iPhone 6 Logic Board Replacement: шаг 20, изображение 1 из 1
    • Remove the SIM card tray assembly from the iPhone.
    • When reinserting the SIM card, ensure that it is in the proper orientation relative to the tray.
  21. iPhone 6 Logic Board Replacement, Logic Board: шаг 21, изображение 1 из 2 iPhone 6 Logic Board Replacement, Logic Board: шаг 21, изображение 2 из 2
    • Use the flat end of a spudger to disconnect the Lightning connector assembly cable and fold it out of the way of the speaker.
  22. iPhone 6 Logic Board Replacement: шаг 22, изображение 1 из 2 iPhone 6 Logic Board Replacement: шаг 22, изображение 2 из 2
    • Use the point of a spudger to lift the antenna cable connector up off of its socket on the logic board.
  23. iPhone 6 Logic Board Replacement: шаг 23, изображение 1 из 1
    • Remove the following Phillips screws from the upper cable bracket:
    • One 2.9 mm screw
    • One 2.2 mm screw
  24. iPhone 6 Logic Board Replacement: шаг 24, изображение 1 из 2 iPhone 6 Logic Board Replacement: шаг 24, изображение 2 из 2
    • Remove the upper cable bracket from the iPhone.
  25. iPhone 6 Logic Board Replacement: шаг 25, изображение 1 из 3 iPhone 6 Logic Board Replacement: шаг 25, изображение 2 из 3 iPhone 6 Logic Board Replacement: шаг 25, изображение 3 из 3
    • When disconnecting the following connectors, only pry up on the connector, not the socket on the logic board or you risk permanent damage.
    • Use the flat end of a spudger to lift the power button and flash assembly cable connector up off of its socket.
    • Lift the volume control cable connector up out of its socket on the logic board.
  26. iPhone 6 Logic Board Replacement: шаг 26, изображение 1 из 1
    • Remove the following four Phillips screws from the Wi-Fi antenna:
    • One 1.5 mm screw
    • One 1.4 mm screw
    • Two 2.1 mm screws
  27. iPhone 6 Logic Board Replacement: шаг 27, изображение 1 из 2 iPhone 6 Logic Board Replacement: шаг 27, изображение 2 из 2
    • Remove the Wi-Fi antenna from the iPhone.
    • Be careful not to touch any metal to metal contact points with your bare fingers—use tweezers or gloves. Finger oils may disrupt conductivity. If you do touch any of these components, clean them with a degreaser like windex or isopropyl alcohol before reassembly.
  28. iPhone 6 Logic Board Replacement: шаг 28, изображение 1 из 1
    • Remove the two 1.6 mm Phillips screws from the grounding bracket.
  29. iPhone 6 Logic Board Replacement: шаг 29, изображение 1 из 2 iPhone 6 Logic Board Replacement: шаг 29, изображение 2 из 2
    • Remove the grounding bracket from the iPhone.
  30. iPhone 6 Logic Board Replacement: шаг 30, изображение 1 из 2 iPhone 6 Logic Board Replacement: шаг 30, изображение 2 из 2
    • Remove the following Phillips screws securing the angled logic board bracket.
    • One 2.6 mm screw
    • One 1.3 mm screw, located horizontally in the upper sidewall of the iPhone.
  31. iPhone 6 Logic Board Replacement: шаг 31, изображение 1 из 2 iPhone 6 Logic Board Replacement: шаг 31, изображение 2 из 2
    • Remove the angled logic board bracket.
  32. iPhone 6 Logic Board Replacement: шаг 32, изображение 1 из 1
    • Remove the single 1.2 mm Phillips screw securing the antenna interconnect cable to the logic board.
  33. iPhone 6 Logic Board Replacement: шаг 33, изображение 1 из 2 iPhone 6 Logic Board Replacement: шаг 33, изображение 2 из 2
    • Use the point of a spudger to fold the antenna interconnect cable up out of the way of the logic board.
  34. iPhone 6 Logic Board Replacement: шаг 34, изображение 1 из 3 iPhone 6 Logic Board Replacement: шаг 34, изображение 2 из 3 iPhone 6 Logic Board Replacement: шаг 34, изображение 3 из 3
    • Use the flat end of a spudger to lift the camera cable connector straight up out of its socket on the logic board.
    • Be sure to only pry on the connector not the socket itself or you can cause permanent damage to the logic board.
    • Fold the camera cable up out of the way of the logic board.
  35. iPhone 6 Logic Board Replacement: шаг 35, изображение 1 из 1
    Standoff Screwdriver for iPhones
    $5.49
    Купить
    • Remove the following screws securing the logic board to the rear case:
    • Two 1.9 mm Phillips screws
    • One 2.3 mm standoff screw
    • Standoff screws are best removed using a standoff screwdriver or bit.
    • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
  36. iPhone 6 Logic Board Replacement: шаг 36, изображение 1 из 2 iPhone 6 Logic Board Replacement: шаг 36, изображение 2 из 2
    • Use the flat end of a spudger to lift the battery connector end of the logic board up slightly, just enough to grab with your fingers.
    • Insert the spudger near the metal shields below the SIM card tray to avoid damaging any chips or sockets.
  37. iPhone 6 Logic Board Replacement: шаг 37, изображение 1 из 3 iPhone 6 Logic Board Replacement: шаг 37, изображение 2 из 3 iPhone 6 Logic Board Replacement: шаг 37, изображение 3 из 3
    • Lift the battery connector end of the logic board and pull it up and out of the rear case.
    • Be careful not to snag the logic board on any cables.
Заключение
655 участников успешно повторили данное руководство.
Sam Goldheart
Участник с: 10/18/12
465 659 Репутация
Автор 538 руководств
Команда
iFixit Участник iFixit
Staff
135 членов
Автор 16 757 руководств
123 Комментариев
is there a way to swap only the memory component instead of the whole thing?
jonesandrew1414 - Ответить
Yes, you can, but you will need to have some serious soldering skills. But in theory you can replace the memory chip with another memory chip that has been reprogrammed to fit your phone's serial number.
Didrik -
Anyone an idea, where I can find the logic board?
Stijn Laurent - Ответить
have you found one?
tishseabrook -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 17
За последние 7 дней: 176
За последние 30 дней: 713
За всё время: 968,961
