iPhone 7 Plus Front Camera and Sensor Cable Replacement
Выберете то, что вам нужно
  1. iPhone 7 Plus Front Camera and Sensor Cable Replacement, Pentalobe Screws: шаг 1, изображение 1 из 1
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.4 mm pentalobe screws at the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
  2. iPhone 7 Plus Front Camera and Sensor Cable Replacement, Mark your opening picks: шаг 2, изображение 1 из 3 iPhone 7 Plus Front Camera and Sensor Cable Replacement, Mark your opening picks: шаг 2, изображение 2 из 3 iPhone 7 Plus Front Camera and Sensor Cable Replacement, Mark your opening picks: шаг 2, изображение 3 из 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  3. iPhone 7 Plus Front Camera and Sensor Cable Replacement, Anti-Clamp instructions: шаг 3, изображение 1 из 3 iPhone 7 Plus Front Camera and Sensor Cable Replacement, Anti-Clamp instructions: шаг 3, изображение 2 из 3 iPhone 7 Plus Front Camera and Sensor Cable Replacement, Anti-Clamp instructions: шаг 3, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Anti-Clamp
    $24.95
    Купить
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  4. iPhone 7 Plus Front Camera and Sensor Cable Replacement: шаг 4, изображение 1 из 3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: шаг 4, изображение 2 из 3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: шаг 4, изображение 3 из 3
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  5. iPhone 7 Plus Front Camera and Sensor Cable Replacement: шаг 5, изображение 1 из 2 iPhone 7 Plus Front Camera and Sensor Cable Replacement: шаг 5, изображение 2 из 2
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the iPhone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick into the gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  6. iPhone 7 Plus Front Camera and Sensor Cable Replacement, Heat the display: шаг 6, изображение 1 из 1
    • The next three steps show how to separate the screen using a suction cup.
    • Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or prepare an iOpener and apply it to the lower edge of the phone for about 90 seconds in order to soften up the adhesive underneath.
  7. iPhone 7 Plus Front Camera and Sensor Cable Replacement, Separate the display: шаг 7, изображение 1 из 2 iPhone 7 Plus Front Camera and Sensor Cable Replacement, Separate the display: шаг 7, изображение 2 из 2
    • Apply a suction cup to the lower half of the front panel, just above the home button.
    • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
  8. iPhone 7 Plus Front Camera and Sensor Cable Replacement: шаг 8, изображение 1 из 3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: шаг 8, изображение 2 из 3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: шаг 8, изображение 3 из 3
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
    • The watertight adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
  9. iPhone 7 Plus Front Camera and Sensor Cable Replacement: шаг 9, изображение 1 из 3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: шаг 9, изображение 2 из 3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: шаг 9, изображение 3 из 3
    • Slide the opening pick up the left edge of the phone starting at the lower edge and moving towards the volume control buttons and silent switch, breaking up the adhesive holding the display in place.
    • Stop near the top left corner of the display.
    • Do not try to pry the top edge of the display away from the rear case, as it is held in place by plastic clips that may break.
  10. iPhone 7 Plus Front Camera and Sensor Cable Replacement, Screen information: шаг 10, изображение 1 из 1
    • There are delicate cables along the right edge of your iPhone. Don't insert your pick here, as you may damage the cables.
  11. iPhone 7 Plus Front Camera and Sensor Cable Replacement: шаг 11, изображение 1 из 3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: шаг 11, изображение 2 из 3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: шаг 11, изображение 3 из 3
    • Re-insert your tool at the lower right corner of the iPhone, and slide it around the corner and up the right side of the phone to separate the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the display cables.
  12. iPhone 7 Plus Front Camera and Sensor Cable Replacement: шаг 12, изображение 1 из 2 iPhone 7 Plus Front Camera and Sensor Cable Replacement: шаг 12, изображение 2 из 2
    • Gently pull up on the suction cup to lift up the bottom edge of the display.
    • Do not raise the display more than 15º or you'll risk straining or tearing the ribbon cables connecting the display.
    • Pull on the small nub on the suction cup to remove it from the front panel.
  13. iPhone 7 Plus Front Camera and Sensor Cable Replacement: шаг 13, изображение 1 из 3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: шаг 13, изображение 2 из 3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: шаг 13, изображение 3 из 3
    • Slide an opening pick underneath the display around the top left corner and along the top edge of the phone to loosen the last of the adhesive.
  14. iPhone 7 Plus Front Camera and Sensor Cable Replacement: шаг 14, изображение 1 из 2 iPhone 7 Plus Front Camera and Sensor Cable Replacement: шаг 14, изображение 2 из 2
    • Slide the display assembly slightly down (away from the top edge of the phone) to disengage the clips holding it to the rear case.
  15. iPhone 7 Plus Front Camera and Sensor Cable Replacement: шаг 15, изображение 1 из 3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: шаг 15, изображение 2 из 3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: шаг 15, изображение 3 из 3
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
  16. iPhone 7 Plus Front Camera and Sensor Cable Replacement, Battery Disconnection: шаг 16, изображение 1 из 1
    • Remove the following four tri-point Y000 screws securing the lower display cable bracket to the logic board:
    • Three 1.2 mm screws
    • One 2.6 mm screw
  17. iPhone 7 Plus Front Camera and Sensor Cable Replacement: шаг 17, изображение 1 из 2 iPhone 7 Plus Front Camera and Sensor Cable Replacement: шаг 17, изображение 2 из 2
    • Remove the lower display cable bracket.
  18. iPhone 7 Plus Front Camera and Sensor Cable Replacement: шаг 18, изображение 1 из 3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: шаг 18, изображение 2 из 3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: шаг 18, изображение 3 из 3
    • Use the point of a spudger to lift the battery connector out of its socket on the logic board.
    • Bend the connector cable up slightly to prevent it from making contact with the socket and providing power to the phone.
  19. iPhone 7 Plus Front Camera and Sensor Cable Replacement, Display Assembly: шаг 19, изображение 1 из 3 iPhone 7 Plus Front Camera and Sensor Cable Replacement, Display Assembly: шаг 19, изображение 2 из 3 iPhone 7 Plus Front Camera and Sensor Cable Replacement, Display Assembly: шаг 19, изображение 3 из 3
    • Make sure the battery is disconnected before you disconnect or reconnect the cables in this step.
    • Use the flat end of a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board.
    • To re-attach press connectors, press down on one end until it clicks into place, then repeat on the other end. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
    • If you have a blank screen, white lines on the display, or partial or complete lack of touch response after reassembling your phone, try disconnecting and carefully reconnecting both of these cables and make sure they are fully seated.
  20. iPhone 7 Plus Front Camera and Sensor Cable Replacement: шаг 20, изображение 1 из 3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: шаг 20, изображение 2 из 3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: шаг 20, изображение 3 из 3
    • Remove the three tri-point Y000 screws securing the bracket over the front panel sensor assembly connector:
    • One 1.3 mm screw
    • Two 1.0 mm screws
    • Remove the bracket.
  21. iPhone 7 Plus Front Camera and Sensor Cable Replacement: шаг 21, изображение 1 из 2 iPhone 7 Plus Front Camera and Sensor Cable Replacement: шаг 21, изображение 2 из 2
    • Disconnect the front panel sensor assembly connector from its socket on the logic board.
    • This press connector should also be reconnected one end at a time to minimize the risk of bending.
  22. iPhone 7 Plus Front Camera and Sensor Cable Replacement: шаг 22, изображение 1 из 1
  23. iPhone 7 Plus Front Camera and Sensor Cable Replacement, Earpiece Speaker: шаг 23, изображение 1 из 1
    • Remove the five Phillips screws securing the earpiece speaker bracket:
    • Two 1.8 mm screws
    • One 2.3 mm screw
    • One 2.4 mm screw
    • One 2.8 mm screw
  24. iPhone 7 Plus Front Camera and Sensor Cable Replacement: шаг 24, изображение 1 из 1
    • Remove the earpiece speaker bracket.
  25. iPhone 7 Plus Front Camera and Sensor Cable Replacement: шаг 25, изображение 1 из 3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: шаг 25, изображение 2 из 3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: шаг 25, изображение 3 из 3
    • Use the flat end of a spudger to lift the front-facing camera from its housing.
    • Gently bend the camera ribbon cable to the side to clear the way to the earpiece speaker underneath.
  26. iPhone 7 Plus Front Camera and Sensor Cable Replacement: шаг 26, изображение 1 из 1
    • Remove the earpiece speaker.
    • Don't touch the four spring contacts with your fingers—your skin oils may cause a malfunction. If accidentally touched, clean the contacts gently with isopropyl alcohol (90% or higher).
  27. iPhone 7 Plus Front Camera and Sensor Cable Replacement, Front Camera and Sensor Cable: шаг 27, изображение 1 из 2 iPhone 7 Plus Front Camera and Sensor Cable Replacement, Front Camera and Sensor Cable: шаг 27, изображение 2 из 2
    • Gently fold the camera and attached ribbon cable toward the bottom of the iPhone to allow access to the components underneath.
  28. iPhone 7 Plus Front Camera and Sensor Cable Replacement: шаг 28, изображение 1 из 2 iPhone 7 Plus Front Camera and Sensor Cable Replacement: шаг 28, изображение 2 из 2
    • The sensors on this step are fragile. To increase your chances of removing them without damage, use your iOpener or hair dryer to apply heat to the upper portion of the display before you proceed. Alternatively, add a drop or two of isopropyl alcohol and let it penetrate under the sensors before you pry them up.
    • Slide a spudger under the ambient light sensor flex cable, and lift the sensor out of its housing.
  29. iPhone 7 Plus Front Camera and Sensor Cable Replacement: шаг 29, изображение 1 из 3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: шаг 29, изображение 2 из 3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: шаг 29, изображение 3 из 3
    • Slide the tip of a spudger underneath the proximity sensor flex cable, and lift the sensor out of its housing.
  30. iPhone 7 Plus Front Camera and Sensor Cable Replacement: шаг 30, изображение 1 из 3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: шаг 30, изображение 2 из 3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: шаг 30, изображение 3 из 3
    • Insert the sharp edge of an iFixit opening tool underneath the camera assembly's flex cable, on the opposite side from the front-facing camera.
    • If necessary, use an iOpener or hair dryer to heat the top portion of the display and soften the adhesive securing the flex cable.
    • Pry up to separate the edge of the flex cable from the back of the display.
  31. iPhone 7 Plus Front Camera and Sensor Cable Replacement: шаг 31, изображение 1 из 3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: шаг 31, изображение 2 из 3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: шаг 31, изображение 3 из 3
    • Insert the point of a spudger underneath the same portion of the flex cable that you separated in the previous step.
    • Continue separating the remainder of the flex cable, pushing the spudger toward the row of circular gold earpiece speaker contacts.
  32. iPhone 7 Plus Front Camera and Sensor Cable Replacement: шаг 32, изображение 1 из 1
    • Continue using your spudger to carefully separate the last of the flex cable from the back of the display.
  33. iPhone 7 Plus Front Camera and Sensor Cable Replacement: шаг 33, изображение 1 из 3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: шаг 33, изображение 2 из 3 iPhone 7 Plus Front Camera and Sensor Cable Replacement: шаг 33, изображение 3 из 3
    • Remove the front camera and sensor cable assembly.
    • A piece of black double-sided insulating tape lies between the display and three rows of copper contacts on the back of the camera/sensor cable. It may remain stuck to the display, or it may come off with the cable.
    • When reassembling, verify the tape is in place, or else cover the contacts on the back of the cable with an appropriate tape, such as Kapton tape.
Заключение
113 участников успешно повторили данное руководство.
Jeff Suovanen
Участник с: 08/06/13
428 055 Репутация
Автор 259 руководств
Команда
iFixit Участник iFixit
Staff
135 членов
Автор 16 767 руководств
17 Комментариев
Do I have to do this if i buy a new phone screen or do they usually come with one?
Tom Robinson - Ответить
If this Speaker is Not Working or it has any Noise Issues, Apple will Replace whole Front Display Section. Under their Policy, they won’t repair it. Neither Fully Replace your iPhone, only Front Panel Replacement.
macktm -
Does 7 and 7plus has the same camera/sensor strip?
Salman Siddeeque Ali - Ответить
No, it’s a bit different.
The spacing between the metal dots for the earspeaker isn’t there on the 7+ model, but is on the 7.
Benjamin Convents -
Anybody got a solution to earpiece not working after ribbon swap?
Seems to be mega common with this repair. I’ve heard a few ideas but nothing concrete. More advice about this issue would be greatly appreciated by me and a bunch of people.
michael wehner - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 9
За последние 7 дней: 87
За последние 30 дней: 362
За всё время: 116,603
