Введение
根据本指南的操作来更换损坏或工作不正常的Switch的风扇。
Switch 使用JIS标准的螺丝,如果没有对应的螺丝刀,使用普通十字螺丝刀也可以,但一定注意不要把螺丝弄花。iFixit的十字螺丝刀与JIS的螺丝相兼容。
注意:当你拆除屏蔽板时,你需要更换屏蔽板和散热器之间的导热膏。由于普通的导热膏不是为弥合大的缝隙而设计的,最接近的替代品是K5 Pro粘性导热膏。
注意:本指南以及我们出售的零件与2017年发布的原始任天堂Switch型号(HAC-001)以及2019年发布的较新型号(HAC-001(-01))兼容。
Выберете то, что вам нужно
Инструмент, используемый на этом этапе:Magnetic Project Mat$19.95
使用 Y00 螺丝刀拧下固定在后盖上的 4 颗 6.3 毫米螺丝。
使用 JIS000 螺丝刀,或者 iFixIt PH000 螺丝刀取下用于固定后面板的螺丝:
一颗在主机顶部的散热器出口旁,长度为2.5毫米的螺丝
两颗在主机底部的充电接口两侧,长度为2.5毫米的螺丝
197 участников успешно повторили данное руководство.
Особая благодарность этим переводчикам:
100%
Эти переводчики помогают нам починить мир! Хотите внести свой вклад?
Начните переводить ›
45 Комментариев
If your joycons are not charging, it could be the fans fault as they seem to share a 1.8v and or 5v rail, I had both joycons refusing to charge, and the fan was not working, so by replacing the fan, it had them charging properly again.
oh? i was wondering why my joycons died and never turned on. i though the hot switch short circuited them. the same thing happened to mine. The fan died as well as my joycons. very useful mate. thanks for the info!
I changed the fan and it still don’t charge my Joycon. What should I do?
baron154 -
I’ve recently found a video that shows what can be wrong with Switch with the same issue, but working fan https://www.youtube.com/watch?v=WuQC3ipu... . In the comments people confirmed several times that it helps.
Andrey -
If I'm just replacing the fan, do I need to clean off/reapply any thermal paste?
