Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
Read me: This guide is archived - EXISTING ERRORS WILL NOT BE CORRECTED. Many laptops covered by this guide usually need a set of aftermerket replacement feet with better longevity then the factory feet with anti-slip options being commonplace. Unless your OEM feet are still intact, it is best to upgrade the set as a pair with anti-slip replacements using this guide: Removing factory feet from a Mac Laptop (Non-Retina)
If your Mac laptop is running hotter then you would like, this guide will show you how to install rubber feet to lift the laptop to allow for additional cooling of the system.
Read before starting: While this guide will help reduce the temperature your Mac runs at, early systems (2006-2012 MacBook/Pro) will always run hotter then Retina systems by design. Apple relies on the ports to provide fresh air for the chassis and reuses the hot air in the system. This is not an issue with the rMBP. These laptops have real cooling and will see reduced temperature drops.
13" MacBook Pro only (Optical drive/Retina): 13" models lack a dGPU. These systems will not see as much of a temperature reduction as there is less heat the system needs to disperse due to this omission. This does not apply to dGPU systems (15”/17” MacBook Pro).
In the original guide, the author used a Early 2009 17” MacBook Pro was used by the author. Before this fix, the system regularly ran up to 180° F without taller feet. The operating temperature was reduced to 122° after adding taller feet.
Инструменты
Инструменты не указаны.
Запчасти
  1. Do not install the replacement feet on top of the factory installed feet. These may break off if the system is moved in the right way.
    • Do not install the replacement feet on top of the factory installed feet. These may break off if the system is moved in the right way.
    • Place your MacBook upside down on a clean flat surface.
    • Clean the laptop surface with rubbing alcohol or a similar cleaner.
    • Identify where you would like to place your new rubber feet. The new feet should be placed somewhere near the factory installed feet. Avoid placing the new feet on curved edges.
  2. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  3. Peel the paper backing off each foot. Once this is done, install them onto the laptop. Peel the paper backing off each foot. Once this is done, install them onto the laptop. Peel the paper backing off each foot. Once this is done, install them onto the laptop.
    • Peel the paper backing off each foot. Once this is done, install them onto the laptop.
Финишная черта
12 участников успешно повторили данное руководство.
Nick
Участник с: 10.11.2009
54 516 Репутация
Автор 39 руководств
Команда
Master Techs Участник Master Techs
Community
292 членов
Автор 835 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 26
За последние 30 дней: 92
За всё время: 24,818
