Removing factory feet from a Mac Laptop (Non-Retina)
Выберете то, что вам нужно
  1. Removing factory feet from a Mac Laptop (Non-Retina), Remove the bottom cover: шаг 1, изображение 1 из 2 Removing factory feet from a Mac Laptop (Non-Retina), Remove the bottom cover: шаг 1, изображение 2 из 2
    • I am using a 2011 13" MacBook Pro. Most machines are similar, but variations may exist.
    • If possible, disconnect the battery to protect your components once the bottom is removed.
    • Remove the bottom cover of your MacBook with the guide for your specific system.
  2. Removing factory feet from a Mac Laptop (Non-Retina), Removing failed feet: шаг 2, изображение 1 из 3 Removing factory feet from a Mac Laptop (Non-Retina), Removing failed feet: шаг 2, изображение 2 из 3 Removing factory feet from a Mac Laptop (Non-Retina), Removing failed feet: шаг 2, изображение 3 из 3
    • Before removing the good feet, remove the failed feet first. These may come off without disassembly if they have fully failed.
    • After removing the damaged feet, remove the intact feet. Follow the disassembly guide for your specific Mac.
  3. Removing factory feet from a Mac Laptop (Non-Retina), (Full set replacement only) Removing intact feet: шаг 3, изображение 1 из 3 Removing factory feet from a Mac Laptop (Non-Retina), (Full set replacement only) Removing intact feet: шаг 3, изображение 2 из 3 Removing factory feet from a Mac Laptop (Non-Retina), (Full set replacement only) Removing intact feet: шаг 3, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    iFixit Opening Picks (Set of 6)
    Купить
    • To remove the intact feet, score the internal plug. Once scored, remove the plug with a guitar pick.
    • After removing the inner plug, push the foot out with a spudger or screwdriver.
  4. Removing factory feet from a Mac Laptop (Non-Retina), Install the new feet: шаг 4, изображение 1 из 2 Removing factory feet from a Mac Laptop (Non-Retina), Install the new feet: шаг 4, изображение 2 из 2
    Adhesive Cleanup Kit (Set of 12)
    Купить
    • If the adhesive ring remains, remove it first. Clean the chassis with denatured alcohol or adhesive cleaner.
    • After removing the old feet, install the new set onto the bottom cover.
    • Re-install the cover on the computer.
Финишная черта
4 участников успешно повторили данное руководство.
Nick
Участник с: 11/10/09
88 809 Репутация
Автор 49 руководств
Команда
Master Techs Участник Master Techs
Community
322 членов
Автор 2 527 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 14
За последние 30 дней: 49
За всё время: 4,354
