Введение
If you purchased a Xbox Wireless Receiver for Windows and are wondering how to use it on Windows 7 or 8.x, this guide will show you how to install the drivers. Since Microsoft is aggressively pushing Windows 10 (despite many users not wanting it or waiting), problems like this will come up.
Since Microsoft wants to make this as hard as possible for Windows 7* or 8.x** users, this guide will show you how to manually install the driver and get it working. IMPORTANT: While my screenshots show Windows 7, it is no longer supported as of 1/14/2020.
**IMPORTANT: WINDOWS EOL NOTICES**
*AS OF 1/14/2020, WINDOWS 7 IS END OF LIFE. The author personally will not support users with Windows 7 systems. However this method can still be used on these systems.
**2023 Win8 EOL warning: As of 1/10/2023, Windows 8.1 will be end of life. As of 12/14/2021, I will no longer be supporting Windows 8.1 users. However, for the time being I will do my best to keep this guide reasonably current - until 1/1/2023 at which point I will consider this guide “obsolete”.
It will remain up for the forseeable future (even after EOL for Win7 and 8.x), but revisions will no longer be made after 1/1/2023.
Guide notes
  • In most cases, the receiver will pick up the driver correctly, but needs encouragement. However, I have included manual installation instructions for situations where this does not happen.
  • Windows 10 users: Refer to the Windows 10 guide.
  1. Plug the Xbox Wireless Receiver into your PC. Note: before going further into this guide, see if the driver installs automatically. Plug the Xbox Wireless Receiver into your PC. Note: before going further into this guide, see if the driver installs automatically.
    • Plug the Xbox Wireless Receiver into your PC. Note: before going further into this guide, see if the driver installs automatically.
  2. Try this method first. Microsoft has pulled the driver from being publicly downloaded. Before opening Device Manager, see if it installs automatically. If this does not work, the driver will need to be installed manually.
    • Try this method first. Microsoft has pulled the driver from being publicly downloaded.
    • Before opening Device Manager, see if it installs automatically. If this does not work, the driver will need to be installed manually.
  3. Open Device Manager. Each version of Windows is different. Windows 7: Open the start menu and right click Computer. Select Manange and locate Device Manager. Windows 8.x: Right click the Windows logo in the taskbar. Select Device Manager.
    • Open Device Manager. Each version of Windows is different.
    • Windows 7: Open the start menu and right click Computer. Select Manange and locate Device Manager.
    • Windows 8.x: Right click the Windows logo in the taskbar. Select Device Manager.
    • Double click XBOX ACC and verify you get Code 28. Click Update Driver and Search automatically for updated driver software.
  4. Refer to the guide comments for WIndows 7/8.x 32-bit .cab files. If the automatic driver install fails, download the appropriate .cab installation file.
    • Refer to the guide comments for WIndows 7/8.x 32-bit .cab files.
    • If the automatic driver install fails, download the appropriate .cab installation file.
    • Select Browse my computer for driver software.
    • Locate the folder where the driver is downloaded, and select Copy address as text. Paste the location into the box under Search for drivers in this lcoation:. Click Next.
  5. If you get an error on Windows 7, install the User-Mode and Kernel-Mode Driver Framework Driver (Version 1.11) update. Just in case, I have archived these updates.
Заключение
3 участников успешно повторили данное руководство.
Nick
Участник с: 10.11.2009
66 335 Репутация
Автор 40 руководств
Команда
Master Techs Участник Master Techs
Community
300 членов
Автор 1 014 руководств
Комментариев: 21
I assume this does not work with the new version of the dongle
Jason Douglas - Ответить
The small one only works in Windows 10. The fat one works in 7/8.x and 10. There is a dedicated W10 guide with a warning related to drivers.
Nick -
My dongle has version 1713 printed on it (tiny font) and it worked on W7. Some details here
P P -
Thank you. It's a shame. Such intentional and shady practices from Microsoft, blockade on a driver. You seem to really know your stuff… do you know if the Windows 10 dongle has features the old one does not? Since I don't even need to google it to know the old dongle is no longer for sale outside of second-hand.
Not that I'm aware of.
I can still find the old one new so it's available. I doubt it's discontinued.
Nick -
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 19
За последние 30 дней: 104
За всё время: 27,548
