Введение
If you purchased a Xbox Wireless Receiver for Windows and are wondering how to use it on Windows 7 or 8.x, this guide will show you how to install the drivers. Since Microsoft is aggressively pushing Windows 10 (despite many users not wanting it or waiting), problems like this will come up.
Since Microsoft wants to make this as hard as possible for Windows 7* or 8.x** users, this guide will show you how to manually install the driver and get it working. IMPORTANT: While my screenshots show Windows 7, it is no longer supported as of 1/14/2020.
**IMPORTANT: WINDOWS EOL NOTICES**
*AS OF 1/14/2020, WINDOWS 7 IS END OF LIFE. The author is no longer supporting Windows 7. However, this method can still be used on these systems.
**2023 Win8 EOL warning: As of 1/10/2023, Windows 8.1 will be end of life. As of 12/14/2021, I will no longer support Windows 8.1 users. I will update this guide to correct critical mistakes until 1/1/2023, at which point I will consider the guide "obsolete" and will no longer fix it.
NOTE: While I will no longer be supporting this guide after 1/1/2023, I will keep it available for the foreseeable future unless there is a major issue that has caused major system breakdowns.
Guide notes
- In most cases, the receiver will pick up the driver correctly, but needs encouragement. However, I have included manual installation instructions for situations where this does not happen.
- Windows 10 users: Refer to the Windows 10 guide.
Plug the Xbox Wireless Receiver into your PC. Note: before going further into this guide, see if the driver installs automatically.
Before opening Device Manager, see if it installs automatically. If this does not work, the driver will need to be installed manually.
Open Device Manager. Each version of Windows is different.
Windows 7: Open the start menu and right click Computer. Select Manange and locate Device Manager.
Windows 8.x: Right click the Windows logo in the taskbar. Select Device Manager.
Double click XBOX ACC and verify you get Code 28. Click Update Driver and Search automatically for updated driver software.
If the automatic driver install fails, download the appropriate .cab installation file.
Select Browse my computer for driver software.
Locate the folder where the driver is downloaded, and select Copy address as text. Paste the location into the box under Search for drivers in this lcoation:. Click Next.
To verify the driver was installed correctly, check under Network Adapters. This is where the adapter appears if it installed correctly.
3 участников успешно повторили данное руководство.
Комментариев: 21
I assume this does not work with the new version of the dongle
The small one only works in Windows 10. The fat one works in 7/8.x and 10. There is a dedicated W10 guide with a warning related to drivers.
Nick -
Thank you. It's a shame. Such intentional and shady practices from Microsoft, blockade on a driver. You seem to really know your stuff… do you know if the Windows 10 dongle has features the old one does not? Since I don't even need to google it to know the old dongle is no longer for sale outside of second-hand.
Not that I'm aware of.
I can still find the old one new so it's available. I doubt it's discontinued.
Nick -
