Введение
Most people aren't happy when a speaker blows out in their car. Old cars can be intimidating because working on them may be difficult at times. This is the perfect Fast Fix guide for anyone who has that problem with their classic Mustang.
Выберете то, что вам нужно
Find the car battery under the hood.
On the battery locate the black negative battery terminal.
Next unscrew the knob on the disconnect.
Lastly move the negative lead away from the batter terminal.
You are now ready to start replacing the speaker.
A philips head screwdriver will be needed.
Lastly make sure to remove the screw completely without stripping out the screw hole.
Locate the wires on the back of the broken speaker.
Remove both the positive and negative wires.
Now locate the new speaker.
Slide the positive and negative wires onto the speaker terminals.
Place the speaker back into the kick panel housing.
Line up the speaker holes with the existing holes in the kick panel.
You have now replaced the speaker.
Еще один человек закончил это руководство.
