Введение
This is a guide on replacing the headlight lamp on a 1980 Honda Prelude.
The headlight helps you and other drivers see at night or during storms. A faulty headlight can cause issues with visibility and with police.
Before following this guide, make sure you replace the headlights in pairs because if one headlight goes out, the other headlight will go out too.
Be sure once you have replaced your headlights to properly throw the old headlights in the trash. Make sure you replace your headlights first before going on the road.
Выберете то, что вам нужно
Turn off the car, pull the key out of the ignition, and turn off the cars lights.
Pull the hood latch underneath the steering wheel.
Open the hood, and place the hood prop in place to hold the hood upward.
Remove the left horizontal adjustment screw by sticking the screwdriver through the hole.
Push the headlamp towards the front of the car.
Remove the bracket from the headlamp, and follow the steps to reassemble the headlamp.
Check the replaced headlight is working by turning the light knob inside the car on.
In Conclusion, learning how to replace your headlight bulb for your 1980 Honda Prelude is important for your, and other driver's safety on the road.
