Введение
Use this guide to install a new oxygen sensor. Oxygen sensors on this vehicle wear out about every 60,000 miles. Replacing an old sensor will help your car run better and stronger while warm and will provide better fuel economy.
The specific oxygen sensor part number varies among the 318i, 325e, 325i, and 318is models, so be sure you have the right sensor for your car before you start the job.
Выберете то, что вам нужно
Start by locating the oxygen sensor connector. On this 325i, it is a circular connector located behind the passenger side shock tower and below the (unused) battery tray.
Unscrew the oxygen sensor connector (lefty, loosey) and unplug it from its socket leading to the engine harness.
Next, locate the oxygen sensor body. It'll be screwed into the downpipe about a foot past the exhaust manifolds.
If your oxygen sensor has a heat shield on it, now is the time to remove it. Use a screwdriver to pry it off and set it aside.
Thread the oxygen sensor wires through the slot in the oxygen sensor wrench.
With the socket seated as best you can on the hex head of the oxygen sensor, use all the strength you can muster to crack it free from its prison in the downpipe.
Grab the body of the sensor and unscrew it from the downpipe.
Once it is free from the threads, pull the sensor body out of the downpipe and remove it from the vehicle.
Next, locate your new sensor. You remembered to buy it, right?
Carefully remove the protective plastic cap from the tip of the sensor.
If your sensor didn't come with any anti-seize on the threads, be sure to apply some to make replacing it in the distant future a bit easier.
Carefully insert the tip of the oxygen sensor into the downpipe and tighten it by hand.
Insert the new oxygen sensor connector into its socket on the harness attached to the chassis.
Twist the connector barrel clockwise (righty tighty) to lock the connection.
Since this particular oxygen sensor can be used on many vehicles, the cable is a bit too long for this particular vehicle.
Luckily, Bosch is awesome and includes two zip ties to keep the cable folded on itself to take up any slack.
Fold the cable on itself and use zip ties to keep it folded. Trim the ends of the zip ties if you desire.
You did it! Enjoy your new found increase in gas mileage!
3 участников успешно повторили данное руководство.
