1985-1988 Volvo 740 Brake Pads Replacement
Выберете то, что вам нужно
  1. 1985-1988 Volvo 740 Brake Pads Replacement, 1985-1988 Volvo 740 Preparing Car For Work: шаг 1, изображение 1 из 2 1985-1988 Volvo 740 Brake Pads Replacement, 1985-1988 Volvo 740 Preparing Car For Work: шаг 1, изображение 2 из 2
    • First, disconnect the battery.
    • Note: Always take the negative terminal off first, then the positive terminal.
    • General Tip: After disconnecting the battery, let the car sit for about 10 minutes. This will allow any residual energy left in the system to settle and it is good practice for any job you are completing.
  2. 1985-1988 Volvo 740 Brake Pads Replacement, 1985-1988 Volvo 740 Jacking Rear Wheels: шаг 2, изображение 1 из 1
    • Turn car off and remove keys from ignition.
    • Place car in park (automatic) or neutral (manual).
    • Engage parking brake.
  3. 1985-1988 Volvo 740 Brake Pads Replacement: шаг 3, изображение 1 из 2 1985-1988 Volvo 740 Brake Pads Replacement: шаг 3, изображение 2 из 2
    • Use hydraulic jack on frame of car to raise car.
    • Place jack head underneath frame couple (pictured).
    • Only necessary to jack the car until the wheels are just off the ground.
  4. 1985-1988 Volvo 740 Brake Pads Replacement: шаг 4, изображение 1 из 2 1985-1988 Volvo 740 Brake Pads Replacement: шаг 4, изображение 2 из 2
    • Place jack stand on frame of car and remove jack.
    • Do not work under car supported only by hydraulic jack, serious injury or death may result.
  5. 1985-1988 Volvo 740 Brake Pads Replacement, Rear Brake Pads: шаг 5, изображение 1 из 2 1985-1988 Volvo 740 Brake Pads Replacement, Rear Brake Pads: шаг 5, изображение 2 из 2
    • Pry off the front hub caps by placing a small flathead screwdriver between hubcap and rim and pulling the screwdriver and hubcap away from tire.
  6. 1985-1988 Volvo 740 Brake Pads Replacement: шаг 6, изображение 1 из 1
    • Loosen each of the five lug nuts on the rear left and rear right tires by turning them counter-clockwise with a 19mm socket wrench.
  7. 1985-1988 Volvo 740 Brake Pads Replacement: шаг 7, изображение 1 из 1
    • Remove tires by pulling directly away from car exposing rear brake disks and calipers.
  8. 1985-1988 Volvo 740 Brake Pads Replacement: шаг 8, изображение 1 из 1
    • Locate the two 17mm caliper guide bolts.
  9. 1985-1988 Volvo 740 Brake Pads Replacement: шаг 9, изображение 1 из 1
    • Remove upper and lower guide bolts on rear left and rear right brake calipers with 17mm crescent wrench.
  10. 1985-1988 Volvo 740 Brake Pads Replacement: шаг 10, изображение 1 из 1
    • Remove rear brake calipers from rotors.
  11. 1985-1988 Volvo 740 Brake Pads Replacement: шаг 11, изображение 1 из 1
    • Locate the two rear brake pad retaining pins on each caliper.
  12. 1985-1988 Volvo 740 Brake Pads Replacement: шаг 12, изображение 1 из 1
    • Remove brake pad retaining pins by punching them out with a 3mm allen key.
  13. 1985-1988 Volvo 740 Brake Pads Replacement: шаг 13, изображение 1 из 1
    • Remove both rear brake pads by pulling them out of calipers.
  14. 1985-1988 Volvo 740 Brake Pads Replacement: шаг 14, изображение 1 из 1
    • Insert two new brake pads into each caliper.
  15. 1985-1988 Volvo 740 Brake Pads Replacement: шаг 15, изображение 1 из 1
    • Replace pin guide behind rear brake pads.
  16. 1985-1988 Volvo 740 Brake Pads Replacement: шаг 16, изображение 1 из 2 1985-1988 Volvo 740 Brake Pads Replacement: шаг 16, изображение 2 из 2
    • Verify that pins are inserted through caliper and brake pad holes and seated over the metal pin guides.
  17. 1985-1988 Volvo 740 Brake Pads Replacement: шаг 17, изображение 1 из 1
    • Tap pins through both rear brake pads and caliper using a wrench.
  18. 1985-1988 Volvo 740 Brake Pads Replacement: шаг 18, изображение 1 из 1
    • Replace rear calipers on rotors.
  19. 1985-1988 Volvo 740 Brake Pads Replacement: шаг 19, изображение 1 из 3 1985-1988 Volvo 740 Brake Pads Replacement: шаг 19, изображение 2 из 3 1985-1988 Volvo 740 Brake Pads Replacement: шаг 19, изображение 3 из 3
    • Finish by performing steps 1-5 in reverse order.
Финишная черта
Еще один человек закончил это руководство.
Garrett Van Ruiten
Участник с: 10/11/10
54 Репутация
Автор 2 руководств
Команду
Cal Poly, Team 3-28, Regan Fall 2010 Участник Cal Poly, Team 3-28, Regan Fall 2010
CPSU-REGAN-F10S3G28
4 членов
Автор 9 руководств
0Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 5
За последние 30 дней: 24
За всё время: 7,327
