Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Use this guide to remove, inspect, and replace the rear brake pads. This guide shows you how to remove the brake pads and install new OEM pads. Worn brake pads increase stopping distance and can cause unwanted noise.
Выберете то, что вам нужно
Firstly Disconnect battery
Always take the negative terminal off first.
'''General Tip After disconnecting the battery leave the car for about 10 mins , This lets any residual energy left in the electrical system to dissapate. It is good practise whatever the job
Turn car off and remove keys from ignition.
Place car in park (automatic) or neutral (manual).
Engage parking brake.
Use hydraulic jack on frame of car to raise car.
Place jack head underneath frame couple (pictured).
Pry off the front hub caps by placing a small flathead screwdriver between hubcap and rim and pulling the screwdriver and hubcap away from tire.
Loosen each of the five lug nuts on the rear left and rear right tires by turning them counter-clockwise with a 19mm socket wrench.
Remove tires by pulling directly away from car exposing rear brake disks and calipers.
Remove upper and lower guide bolts on rear left and rear right brake calipers with 17mm crescent wrench.
Verify that pins are inserted through caliper and brake pad holes and seated over the metal pin guides.
Еще один человек закончил это руководство.
